Results 1 to 2 of 2
    Dec 2018
    Question "Special files" and where to find them - DTS Monaco
    Hi guys,
    I've been using the DTS software for a while, and got some questions. I understand that there is such thing called "special files", among the users of the program, who intend to code (variant coding) an ECU. The meaning is - files that are used specifically in case that the ECU is locked, and seed key calculation is required.
    The special files allow you to avoid the seed key and the need for seed key calculator, by simply unlock the ECU.
    Such files could be: SMR-E, SMR-FD, SMR-M, SMR-V etc.
    Can someone tell me, which ECUs could be unlocked using these files? I mean, for which ECUs exactly these files could be useful (for unlocking/flashing)?
    PM if more convenient
  2. The Following User Says Thank You to Vincent82 For This Useful Post:
    boscoxd14 (25th December, 2021)
  3. #2
    Feb 2017
    Hello Vincent did you found any special files ?
