Does anyone know the correct part number for this car?
Car is keyless - handsfree..
Regards,
Sima
Regards,
Sima
[QUOTE=jodge;3541335]be very careful...if the bcm sw is on this list just walk away...
4BA0A
4CB0A
4CB1A
3ZP0A[/QUOTE
how can u know this sw
Truecode and autel user reports. Those sw-s are all stuck on key learning mode and as far as i know until now the only solution ecu+bcm+2keys from the dealer.
Xtrail, Rogue, Quasqai, doesn't matter only the BCM sw. You can check it with diag. BTW the truecode and advance SP both have warnings
Unfortunately there is no official bulletion and probably not just those sw's are affected.
20 digit pin systems only
Well its kinda shitty situation.
I guess I should make dump of BCM before I start incase something goes wrong.
I tried to read the BCM but the MCU is locked.
Any feedback about this SW?
sorry nothing![]()
Will try tomorrow and let you guys know about this.
Some locksmith did AKL on this car,and was done in 5 minutes the owner says...
Okay
This BCM is safe to do.Had a mini heart attack but all was okay.
you should used to wear an ECG machine during learning![]()
What can be done if I come across a locked down system?
Sent from my SM-G930F using Tapatalk
check this pictures and read the topic
trinicolin (7th July, 2019)
