Thread: Transporter ECU
    Mar 2019
    SK
    Default Transporter ECU
    hi, I have a problem with the T5 transporter, there was a 77kW engine and I installed 96kW, all works well only idle shaking, can anyone adjust it to higher fuel idle? well thank you. ecu 038906016N
    mprog's Avatar
    Feb 2017
    Europe
    Adjust higher fuel idle is not good solution
    Mar 2019
    SK
    what is the appropriate solution please
    mprog's Avatar
    Feb 2017
    Europe
    Injectors problem
    Mar 2019
    SK
    thank you for answering me, whether or not the idle speed had diesel because when I close the air the engine doesn't shake
    Mar 2019
    SK
    my injectors , vds can set idle max 910 and my motor needs 950 and is calm
