Results 1 to 12 of 12
    Feb 2018
    Default Ford Focus RS, bad map, help me
    Hi boys, i have a problem with Ford Focus Mk2 RS 2.5 turbo petrol. This car is already mapped, but i have problem, this car does not accelerate more when I put the fifth gear at 180 KM/h . With six gear this car is perfect. Can i help me? I send my map, but pass in pm for who is help me. Thanks a lot!
    Nov 2016
    uk
    Buy a file mate from proper tuner at the end of the day u own a focus rs would u risk blowing your engine for a free file
    Aug 2012
    nobody help u when u protect file by pass !
    and buy a file from tuner round 100-200 euro whats the problem ???
    Tuning Cars and Trucks, Immo off , DTC delete, DPF off
    Feb 2018
    I would also be willing to pay if someone could correct the problem, the important thing is that someone who is qualified knows where to go to correct
    Feb 2018
    this is same file
    Aug 2012
    Quote Originally Posted by speedforever View Post
    this is same file
    here but your file is totaly crap ;-)
    to lean u requestet 2,2 bar boost and some more
    i fix only your problem
  7. The Following User Says Thank You to icezero2010 For This Useful Post:
    sdtsedat (6th April, 2019)
  8. #7
    Feb 2018
    Quote Originally Posted by icezero2010 View Post
    Goodmorning, i see your file, but you modified only launch control value, this is value for engine speed limit on launch control. Then i don't resolve my problem.
  9. #8
    Aug 2012
    This is rpm limiter by gear
    Gesendet von iPhone mit Tapatalk
  10. The Following User Says Thank You to icezero2010 For This Useful Post:
    speedforever (5th April, 2019)
  11. #9
    Feb 2018
    [QUOTE=icezero2010;3543773]This is rpm limiter by gear
    then I have to do a test as soon as possible. I thank you and I'll let you know as soon as I do the test.
  12. #10
    Aug 2012
    [QUOTE=speedforever;3543778]
    test this if this not your problem look at rlmax u set to 0
    make it to 1 its for reduce load 1cb5b4 and 1 is no correction ;-)
    i never test if u use 0 but lower than 1 is load reduce
  13. The Following User Says Thank You to icezero2010 For This Useful Post:
  14. #11
    Feb 2018
    hi icezero i resolve my problem with your solution. I remake rpm limiter ORI and now this car go fine. Thanks a lot!!
  15. #12
    sdtsedat's Avatar
    Jan 2015
    Belgium
    Long time ago that i see you make file
    Sedat Garip
    Chiptuning Remapping, file service, stage 1 & 2 dyno tested.
    Diesel + petrol All cars
    Manual Adblue dpf egr Opf tested working solutions
    Belgium
    With Kind Regards,
    Don't forget hit thank button if i helped.
