I have a problem with the electronics the pump ford focus, does anyone know what this element ... that you can use something else for a timing valve...engine turns but there is no regulation of fuel
hi, i read all posts about VP44 but i have a question,
what do you think about replacing the broken transistor with an FDD10AN06A0 ?
MAYQUAD (27th May, 2014)
Hi friends i have problem with vp30 I can not solder the RED pin from irzf44n, I need any info where it would be another place that Red Pin to solder ?????
I have see Foto on the First Page......
Thanks alll........
what i need to sold an tranzistor to pcb of vp44.ori wich device i sold
hi
I have opel vectra b 2.0dti year1999.
the pump is bad
I have the bad transistor.
I changed the transistor but the car will not start.
I have tried several transistors (IRFZ44N, 3803.2905 irl .... etc) but to no avail.
I have also tried several PSG damaged modules without results.
the pump is mechanically fine.
I followed the procedure drivergabriel 1 ? post.
I have to reset the module to work?
You are sure that mechanically the pump is ok?
Did you check it well?
BR
hi
yes pump is ok.
I connected an original module and the car starts but does not start with the repaired
car can not turn on unless the last three digits the same as the old pump. These are genuine Bosch last three numbers ..... 003 or 002 .....
If the number ......... 004 will not turn on the car must be the same number of pumps
You need to know from which station you repaired last number of Bosch 002, 003, or 004
