Page 94 of 96 FirstFirst ... 44848990919293949596 LastLast
Results 1,396 to 1,410 of 1429
  1. #1396
    Jan 2022
    Hi guys!
    This post has been so far really useful for me on my journey of bringing back to life my Fiesta from 2001.
    I have the famous VP44 in this one, which stopped working all of a sudden. The errors that I was getting were P1664 and P1564, which indicated me that the mosfet was gone. I opened the main circuit and indeed, one of the pins was gone.
    I replaced the mosfet with another one, placed back to the car and the mosfet started to smoke. I believe that mosfet was already damaged from factory... So, I replaced it again and this time, everything seemed normal.
    As soon as I give ignition, I can measure 12V in the output of the two cables(metering solenoid), so it seems that the mosfet it's actually working. I measured as well on the other solenoid, and it seems to give as well the right value.
    When cranking, I can hear a click click click noise, which I think it's coming from the metering solenoid opening the fuel system.
    There's fuel coming to the 4 injectors, I opened one by one to put the air out until I couldn't see any more air coming out.
    But even doing all of this, the car doesn't start and I still read P1664 and P1564. What am I doing wrong?
  2. #1397
    Yhoni's Avatar
    Jun 2014
    Somewhere in time...
    Hello friends, i can not to weld the wires over the surface. I use tin-lead 40/60 and It does not adhere to the surface.
    I have a soldering iron with temperature control but I can't solder on that surface.
    Could someone give me some advice, please?
    If my post has helped you, do not forget to click on the "THANKS" and "REPUTATION" button !!!
    I do not answer in private questions that can be solved in public.
  3. #1398
    Aug 2021
    Default THANKS!
    THANK YOU! Hi, I would be really grateful if I could get a password
  4. #1399
    Oct 2022
    Hello!
    I have an Opel Frontera 2.2DTI pump with problems.
    Without warning, one day it didn't start anymore.
    The errors are P1631 and P1651.
    Is it just the transistor?
    Thank you!
  5. #1400
    Oct 2022
    In the meanwhile I anticipated and bought these 2 transistors:
    IRLR2905ZTRPBF and IRLR3705ZTRPBF.
    Which will be most suitable?
    Regarding soldering, I would like to test it in advance on a module that was broken.
    Is there any place where I can buy such a thing?
    Thank you very much.
  6. #1401
    Aug 2016
    Spain, Valencia
    everything is very simple, try resistance welding at low current with small pieces of steel wires. Well?
  7. #1402
    Oct 2022
    Romania
    You can try to connect a probe light to solenoid ( fuel metering valve ) wires.
  8. #1403
    Yhoni's Avatar
    Jun 2014
    Quote Originally Posted by venkiborg View Post
    Hello friend, english is not my language native and i don´t understand well you.
    Could you explain again your tip, please?.
    Thanks.
  9. #1404
    gwiazdamb's Avatar
    Aug 2022
    PL EU
    I use this liquid and an ordinary soldering iron and tin without rosin can do it.
    After smearing the wire after 10 seconds, you can solder
    PLEASE PRESS THE " THANKS " BUTTON
  10. The Following 2 Users Say Thank You to gwiazdamb For This Useful Post:
    SERBAN 70 (4th July, 2023), Yhoni (19th December, 2022)
  11. #1405
    Yhoni's Avatar
    Jun 2014
    Quote Originally Posted by gwiazdamb View Post
    Ok friend, thanks for your tip.
  12. #1406
    Oct 2022
    hi guys
    I'm having some problems with the vp44 pump on an AUDI 2.5 tdi. long story short - I replaced the mosfet on the original pump and it failed after 2 days. Then I went to get a known working pump from a car that was drivable. I unbolted it and I put it in a car, made the adaptations using VCDS and the car still shows - controle module faulty - . Over all I tried 3 known working pumps and still no luck.
    In the last year I owned 7 Audis 2.5 tdi and all had a bad pump. I always replaced it with a second hand one and never done any adaptations with VCDS. Car always fired up and worked like it should.
    this one is really making me go insane.
    Have any of you had any similar problems?
  13. #1407
    Home
    With the right pump ?
    Keep in mind, English is not my native language.
  14. #1408
    Oct 2022
    yep... everything is like it should be
  15. #1409
    Mar 2023
    toowoomba
    Default thanks
    Quote Originally Posted by bojo06 View Post
    PC software for test VP44/VP30 via the K line.
    thanks for the post
  16. #1410
    Dec 2019
    Hello, repairing VP44 after unsuccesful repair.
    Have replaced valve first transistor, 7805 reg and ECU back online, but thin hair was ripped on third transistor Q3, can please someone help me with it logic/pinout/model?
