Page 96 of 96 FirstFirst ... 4686919293949596
Results 1,426 to 1,431 of 1431
  1. #1426
    Dec 2018
    Hello masters….
    today I open a module from Ford, and what i see… resistors on edge of pcb are dissoldered…. I try resolde but without success… i try again and again… and nothing…. �� but the bad part, is the plates for solder are disappearing and the soldering wire dont attach….
    someone have a diagram from module??? To try in another solder in another points??? And someone know what type of resistors are??? How many oms??
    thanks in advance
  2. #1427
    Junior Member SERBAN 70's Avatar
    Nov 2014
    Quote Originally Posted by SamuelRib View Post
    Здравствуйте, мастера….
    сегодня открываю модуль от Форда и что вижу… резисторы по краю платы распаяны…. Я пытаюсь перепаять, но безуспешно… пытаюсь снова и снова… и ничего…. �� но самое плохое то, что пластины для припоя исчезают, а паяльная проволока не прикрепляется….
    у кого-нибудь есть схема модуля??? Попробовать еще припаять в других точках??? А кто-нибудь знает, что за резисторы??? Сколько омов??
    заранее спасибо
    здравствуйте. выбросьте его в мусор. ищите либо насос, либо psg5
  3. #1428
    Dec 2018
    Quote Originally Posted by SERBAN 70 View Post
    Another module from BMW or Opel, will work??? changing some thing??? I have it, but dont have Ford
  4. #1429
    Mar 2013
    Nope , not compatible
  5. #1430
    Dec 2016
    Hello guys! I have a question about the capacitor marked as 156-35k. Usually, I see pictures with that condensator showing a black dot, but I saw some pictures of PSG16 modules without this "dot".
    My question is if this capacitor can be blown, or is just a paint dot that they add at factory. Is the one circled on red.
    My pump blown the drain fillament. I tried to rescue the ECU, soldering a modified 20A fuse, but it blown the source fillaments instantly after trying to crank. Actually, I´ve noticed that the FET looked damaged before this, as I saw on the picture of the fuse installed before closing and trying to start.
    At this moment, I have an IRLR3110Z ready for install, and some thermal glue for gluing it to the old FET body.
    I guess it won't matter if I solder the new fet to the top of the old one, or glue it on, I´m correct? Drain is on pin 2 and 4 (back) of this FET looking to datasheet, and the original one should be glued and isolated to the ecu chassis, right? In doubt, I´ve chosen gluing by default (I´ve saw both methods on some videos).
    I´ve also bought for the occasion a coil of lead free tin from Weller, Sn with 3%Ag and 0,5%Cu. I know that the wetting is difficult to get, but should clean it all with IPA alcohol before.
    I will assembly the new FET soon, but not pretty sure if this is going to solve the issue or if any other component on the board is damaged. Any help is welcome! Is a sad problem that a lot of this nice cars are going to the crapyard because an inexpensive part of a silly desing.
    Greetings from Spain!
  6. #1431
    Jun 2024
    erase the error memory which just keeps the error codes or erase the entiry memory of the block allowing for reprogramming of the module?
