Page 52 of 96 FirstFirst ... 242474849505152535455565762 ... LastLast
Results 766 to 780 of 1430
  1. #766
    Newbie sphhoppenb's Avatar
    Hi foks,
    I tried the repair on a '99 bmw e46 320d m47. the car does not start. No high pressure fuel out of the lines when I lose the bolt on the injector, I can stop the flow with my finger. I suppose 2000 atmosphere should blow the fuel to the hood. When I examined the psg5 I noticed that one leg of the transistor came of due to fatigue.
    I did the wiring according to the image I attached. The ifz44n is screwd against the edc housing for cooling. I soldered the blue wire to the aluminum wire and the pink one to the smallest point on the board. This small point was very difficult to get the solder to stick. Is This is ok right?
    Is it ok to put the gray wire to the middle pin of the fet instead of to the screwplate? And is it ok to connect this wire only to this point on the board or does it have to be wired to the other side as well? (like drivergabriel step4).
    How can I check if the fet is alive?
    Greetings from Holland.
  2. #767
    DK Veteran Poptest's Avatar
    Sep 2010
    Default Erasing VP44 maps
    Hello DK,
    Can someone please share how to erase all maps on a psg5 VP44 ecu? We often have to replace PSG5 ecu because all maps have been consumed by previous calibrations. Ecus are still good, but will not accept a new calibration because there are no free maps remaining.
    Thanks a lot.
  3. #768
    DK Veteran zoro1's Avatar
    Bulgaria,Sofia,Vidin
    Quote Originally Posted by sphhoppenb View Post
    Hi foks,
    Well if there is so many glue chanse for ECU to be OK is too smal...
    Quote Originally Posted by Poptest View Post
    Hello DK,
    Thanks a lot.
    There is no way to do this,in the ECU is OTP EPROM and some flash MCU, maps are in EPROM...
    Large nations behave like gangsters ,and young as prostitutes !
  4. #769
    DK Veteran mishu_b's Avatar
    Land of Choice!
    after repairing the ECU of the pump -
    How I can recalibrate the pump?
    now the car fuel consumption increased a lot!
    many thanks for your support!
  5. #770
    Lithuania
    Quote Originally Posted by mishu_b View Post
    Hi, you must change INJECTION QUANTITY, now you have about 7 - 9 mg/str, it must be 3-5.
  6. #771
    Mar 2011
    I think it's a mechanical failure the pump can give you to report errors
    P1220
    In Opel cars then occurs P1220
  7. #772
    Sep 2010
    As far as I know, only the Bosch test stand with VP44 hardware and software can properly calibrate this pump.
  8. #773
    Lithuania
    I know people who make it with solder! I have a dismantling of my car to do this job picture.
    Now my car go very good!
  9. #774
    Quote Originally Posted by zoro1 View Post
    EPROM...
    please do tell me why you think that.
  10. #775
    Mar 2011
    Hi friend s what is the BEST Transistor for
    Opel 2.0 DTH , 2.0 DTL Year 1999 and 2001
    I have IRLR 2905 and IRFZ 44 and IRFZ 48
  11. #776
    miha99's Avatar
    EU
    Use IRFZ 48
  12. #777
    is someone able to answer my questions earlier on this page?
  13. #778
    and also, did anybody ever swaped a edc from another (used) identical bmw pump and got it working ?
  14. #779
    Land of Choice!
    Quote Originally Posted by Min2xx View Post
    you are right - 7-9mg/str.
    I would like to decrese this value as you decribe above - I have Op-Com interface - I tried to read and ajust the values from "Special Functions" - did not work
    where shoudl I look to change this value?
    atb
  15. #780
    Lithuania
    atb
    In pump electronic. Ok, I will make photo.
