Iveco Daily Bsi 503440080122 swap helo need!!
Results 1 to 7 of 7
    Jan 2018
    Downloads
    Uploads
    Default Iveco Daily Bsi 503440080122 swap helo need!!
    I need help with some information
    I programmed daily key. In process of removing and soldering back eeprom. I knocked off few SMD components held up in jig. I donít know what they were resistors, capacitor, diode or else. I replaced off the shelf SMD component with matching color etc.
    No start, cant communicate to BSI by OBD either. so I need to change BSI with second hand one.
    Vehicle details, Iveco Daily 2010
    BSI Magnet Marelli 503440080122
    MCU NEC 70F3238M2GJA
    Eeprom ST 9532W 95320
    I think systems identify each other with VIN,
    My question is will it be ok to just swap 8 pin eeprom (TSSOP-8)
    Or I will have to swap MCU file as well.
    Many suggestion, much appreciated
    Mar 2017
    46
    Downloads
    6
    Uploads
    can you post pic of your bsi
    Jan 2018
    Downloads
    Uploads
    Hungary
    27
    Downloads
    19
    Uploads
    The eprom and processor is paired, so change together.
    Mar 2017
    46
    Downloads
    6
    Uploads
    i mean pic fron your bsi who is broken.
    Jan 2018
    Downloads
    Uploads
    Quote Originally Posted by leaserhu View Post
    Thanks for you advice Sir!
    it will be very hard to switch MCU as so many legs. it ok if i read dump and replace dump in new MCU and replace eerpom file in eeprom chip ?
    hitechservis
    , car is with customer now. once i get the car and pull BSI out. i will send you photo. Thank you.
    Hungary
    27
    Downloads
    19
    Uploads
    If read processor and whrite used and change eprom, worked perfectly.
