With no file, no one will help you
If i helped, don't forget push thanks + rep
Small engine naturally aspirated 16v i don’t think 11l/100km is so desperate.
mancioks (5th April, 2019)
lambda or throttle are comon problem to this cars
but for consume can be bad lambda
Proffesional ECU & TCU Tuning
Petrol and Diesel Engines
File Service
I clean the throttle and body alignement with vcds
I buy a new lambda bosh
I noticed that the empty catalyzer
plz help me
Are there any trouble codes present?
A exhaust leak (near the Lambda sensor) can also cause high fuel consumption.
I noticed a leak Drops of water in the exhaust under the car after the catalyst20190406_114237.jpg
a solution please
Hi, if you don't have any trouble codes please check real value of temperature sensors and lambda probe.
how to check real value
Your VAG COM 409.1 (better vcds lite 1.2)
-engine
- blocks of measured values
https://www.youtube.com/watch?v=dSoNW2blUrM
