Results 1 to 12 of 12
    May 2010
    Default Peugeot 307 2.0 16v IAW 4mp2.01 / BSI motorola HC912
    I have a problem with this car, someone tried to fix it but without success. The problem is that the BSI HC912 file is corrupted, VIN number pppppppppp. I made a virgin BSI and set up PP2000. Now I have a problem with IAW 4MP2.01, the previous master has already done something with AM29F200BB, the read file does not contain a PIN number and the file is damaged. I found another matching file made it to be Virgin, but I can't pair it with BSI to PP2000 because I don't have a PIN code on BSI because it's Virgin, and IAW 4MP2.01 is Virgin so it doesn't contain a PIN code. How do I pair them?
    Dec 2009
    Any PIN with a new key.
  3. The Following User Says Thank You to Zmann For This Useful Post:
    StojkePN (5th June, 2020)
    May 2010
    Thanks I will try with the new transponder and coding over PP2000
    May 2010
    I couldn't match it. Bsi Virgine, Motor ECU Virgine, New transponder. Through the PP2000 program I went to the BSI Replaced option, I entered the VIN number, and the settings that were offered. When entering the PIN code, it displays that the PIN code is incorrect.
    What's the problem?
  6. #5
    Dec 2009
    Quote Originally Posted by StojkePN View Post
    Not viable logic !, how come it says the PIN is wrong as there was no PIN. Some thing went wrong, try from virgin again and notice when programming PIN to BSI at first time, what will say.
    edited: You have incorrect virginised ECU dump and that will not work !
  7. #6
    May 2010
    I’ve worked Virgin a lot of times on this BSI with the HC912 and I’ve never had a problem, but the motor ECU has always been unopened, now someone before me has been working and touching the 29F200 and I don’t know what he did.
    Edit: Does anyone have a valid Virgin dump for Motor ECU IAW 4MP2.01 AM29F200BB?
    Attached is the dump I read from the Motor ECU.
    Magneti marelli
    IAW 4MP2.01
    27K9LK172
    HW 16.530.014
    HW 9642427080
    SW 16.581.024
    SW9646345080
  8. #7
    May 2010
    Can any of this file make virgin or immo off. I tried with the programs Universal immo decoder 3.2, AEtool, Immo service tool 1.2 but they don't do the virgin properly.
  9. #8
    rafal's Avatar
    Jul 2010
    UK - PL
    enjoy......................
    pass=buttons
    need help
    now my goal is to buy xp-005
    who will help?
  10. The Following 5 Users Say Thank You to rafal For This Useful Post:
    achinoto (15th October, 2020), Ecumotor (12th December, 2020), IPrometheus (11th November, 2020), skens (3rd June, 2023), StojkePN (13th June, 2020)
  11. #9
    Mar 2019
    Pass,please.Thank you in advance.
  12. #10
    May 2018
    Quote Originally Posted by rafal View Post
    pass=buttons
    Thanks and rep. The car i want to try have the same flash. i would like to see the info there.
  13. #11
    Dec 2018
    Spain
    plase pass thanks
  14. #12
    Mar 2010
    Please Pass thanks.
