Results 1 to 6 of 6
Hybrid View
    Apr 2016
    Default Ford C-Max 1.6 TDCI Automatic to Manual conversion
    Dear All, thank you for reading my post. Any help is appreciated!
    I have a car Ford Focus C-max 2005 year. 1.6TDCI. The automatic gearbox is broken, so I switched to manual. However, the car runs very bad. One of the problems is: Speedometer says: Gearbox malfunction + ESP function stop working. Also Check engine light is ON. Can I reprogram the ECU, and switch the dump from automatic to manual? The ecu is EDC16C3.
    treble6's Avatar
    Nov 2008
    update to new calibration file from ford using ids,you should find suitable one with manual gearbox for your car
    here is one you can try 8M51-12A650-LF
    not sure if link is working https://mega.nz/#!BlBBmZCJ!5fJ441-PK...ML9ySuH3JOj7b0
    Apr 2016
    Thanks for reply. Problem is that my Flash file size is 1024KB not 2048KB.
    I read in forum, that NO FAP version EDC16C3 is file size 1024KB
    And FAP version of EDC16C34 file size comes in 2048KB. Is it true? I add some photos.
    Need dump of EDC16C3 manual transmission.
    Feb 2010
    Poland
    On ori File youse forscan and change configuration in edc AT on Mt
  5. The Following User Says Thank You to radoslawwiklik For This Useful Post:
    clauberty (16th June, 2021)
  6. #5
    Apr 2016
    -Hi radoslawwiklik, will try and report back. Don't think it's possible thought.
  7. #6
    Mar 2010
    Timisoara
    Quote Originally Posted by radoslawwiklik View Post
    and on dash 720-03-02 x Y x x Y=A -> in my case to remove automatic trans display and trans error
