update to new calibration file from ford using ids,you should find suitable one with manual gearbox for your car
here is one you can try 8M51-12A650-LF
not sure if link is working https://mega.nz/#!BlBBmZCJ!5fJ441-PK...ML9ySuH3JOj7b0
Dear All, thank you for reading my post. Any help is appreciated!
I have a car Ford Focus C-max 2005 year. 1.6TDCI. The automatic gearbox is broken, so I switched to manual. However, the car runs very bad. One of the problems is: Speedometer says: Gearbox malfunction + ESP function stop working. Also Check engine light is ON. Can I reprogram the ECU, and switch the dump from automatic to manual? The ecu is EDC16C3.
Thanks for reply. Problem is that my Flash file size is 1024KB not 2048KB.
I read in forum, that NO FAP version EDC16C3 is file size 1024KB
And FAP version of EDC16C34 file size comes in 2048KB. Is it true? I add some photos.
Need dump of EDC16C3 manual transmission.
On ori File youse forscan and change configuration in edc AT on Mt
clauberty (16th June, 2021)
-Hi radoslawwiklik, will try and report back. Don't think it's possible thought.On ori File youse forscan and change configuration in edc AT on Mt
