Results 1 to 12 of 12
    Member Nicolos's Avatar
    Aug 2018
    Belgium
    Default Corsa D 1.2 z12xep engine ECU no communication and F on dashboard
    Hello everybody
    I have a Corsa D 1.2 Z12XEP.
    After replacement of the engine there is not communication with ECU and there is a F on dashboard.
    I think the problem is not the ecu.
    I have Tech2 scanner ,full scan all the modules are present but with engine ecu there is not communication .I checked all the fuses and relay.
    I have test another ECU but again "no communication ".
    Anybody with the same problem?
    What else I must check?
    Jul 2013
    yorkshire
    Try a jump cable from battery -12 to ecu frame.
  3. The Following User Says Thank You to autoden For This Useful Post:
    Nicolos (7th April, 2019)
    Aug 2018
    Belgium
    Quote Originally Posted by autoden View Post
    On the metal frame there is a ground wire.Where exactly I must jump the cable?I don't see how to do this.
    Aug 2018
    Belgium
    Feb 2013
    UK Bristol
    Did you check ecu communication on the Bench?
    My post helps you? Please Hit Buttons
  7. The Following User Says Thank You to pocinas For This Useful Post:
    Nicolos (8th April, 2019)
  8. #6
    Aug 2018
    Belgium
    There is no communication with ecu.i scan with Tech2 and opcom.Like ecu is not existing. I try a new one and the same"no communication "
  9. #7
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    Check engine to chassis ground cable... As mentioned use directly negative cable from battery to ecu...
    You have power at ecu pins?
  10. The Following User Says Thank You to Panathaole For This Useful Post:
    Nicolos (6th April, 2019)
  11. #8
    Aug 2018
    Belgium
    Il check it tomorrow. I have tis 2000 and i will check terminal 51 on XC2 ( Connector to ECU).
    But now you mention this I think the Brown cable (ground)was cracked.
  12. #9
    Aug 2018
    Belgium
    You mean ground?
  13. #10
    Aug 2018
    Belgium
    Quote Originally Posted by Panathaole View Post
    Problem solved!!!
    You were right.Ground cable was defect.No ground.
  14. #11
    Aug 2018
    Belgium
    Problem solved.
    Brown cable is ground on ecu.
    Not grounded!
    I put a new ground cable and all is ok
    Thanks to all for your Help.
    Saves me a lot of time of research.
  15. #12
    Jul 2013
    yorkshire
    Now we help you, what about you hit the thanks button!
  16. The Following User Says Thank You to autoden For This Useful Post:
