I need help. I've been suffering for days. I received a file from a friend that ORANGE made, but I was not able to report it to the car.
Please help me
Please help me
budata (9th June, 2021), murat332 (9th June, 2021), RadovanPetkovic (9th June, 2021)
I did a little research and concluded that the Virgin file can also be made manually. We don’t all have calculators or the knowledge to do that.
There are two ways to Grunding and Blaupunkt. I distance myself from errors, many files are for CD30 MP3 or just CD30. I couldn't see the difference between which file is possible to do exactly the same. It should be tried.
When we change the data in the file at the given addresses. We get a file that is programmed into the CD player. Then the device becomes DELIVERY STATE. Which means it can log on to any car (for which it is intended) using an OPCOM device or someone else using a PIN CODA from the information display. You can easily find out this PIN code using the FVDI Abritus clon device. I don't know why I didn't manage to marry the CD and the Display (programming) so I succeeded with the OPCOM device.
I tried to clarify the whole process because it was not clear to me and I read so many posts and watched videos. The more I watched the more and more it was not clear to me. Different devices, different procedures, different explanations, many bad jobs are used for the same job ....
I ask more experienced colleagues to correct me if something is wrong.
Huge thanks to "bogege"
This is just to go crazy. He deleted the display safe but prints Radio safe and a beep is heard every second ....
The pin code in the display and CD radio is the same 0417. What could be the problem now?
bogege (9th June, 2021)
Abritus FVDI clone fails me
Opcom clon whatever pin cod I type accepts for the first time
Opcom clon says he did the job successfully
Recommendation?
As for the screen, I'm not sure what was changed on the car. A friend bought it that way. With the Abritus FVDI clone, I can't read the pin code from the instrument panel or from the motor computer. When scanning present devices. Anyone it recognizes prints the VIN chassis number only on the screen and the CD radio has no VIN number.
So it is possible that many parts on the car were not original and the question is how everything is paired ....
Don't confuse "Standing on my Shoulders" with "Treading on my Toes" ..
Currently the car is not available when a friend drives my car again. I'll set up a dump. It may take a while.
Here is the bin file from the info display. As far as I was able to see Pin Cod is like Abritus FVDI read. The Cod pin in the engine computer was also checked. It's exactly the same.
I really don't understand where I'm wrong anymore
