    Newbie Wumpie's Avatar
    Apr 2019
    Germany, Düsseldorf
    Default Display Change HTC M9
    Hi Together,
    i change the Display on my HTC M9 Smartphone, becaus it was broken, i order new one on Ebay, but after replacement the unit boot up and new display says boot error because of changing Hardware, i try to boot with sysnc manager by HTC or boot by choosing the boot option but no result, have found a tool to root the system but think it could be a risk and the unit is totaly damaged
    Any solution to fix this issue ?
    jodge's Avatar
    Mar 2017
    pls post a picture about the boot error
    Apr 2019
    Germany, Düsseldorf
    Default Screenshot from my Mobile
    Electronic is a wonderfull World
    jodge's Avatar
    Mar 2017
    hehe
    It's a simple H-boot menu.
    Let me guess
    You bought this phone with totally boken lcd and trying to fix, and the previous owner didn't told you the custom reco or cooked/rooted system
    Or you trying to do something stupid thing with the reco or the system?
    Whatever....... The problem is the phone sw signature are damaged and the PBL stops the boot chain. (Bcose the modded sw..root reco..etc)
    Put in to fastboot mode check the CID, sw version, pruduct type and reflash with proper factory sw.
    Still a good idea to pass a professional service.
    Last thing double check the volume buttons in this menu up-down and power is the enter
    Apr 2019
    Germany, Düsseldorf
    Problem fixed,
    i use root / flash Tool, so now unit is still wake up, with new Display !
    Phone is my own, it was between my driver seat an the belt holder, so i had display damage
    jodge's Avatar
    Mar 2017
    if you like the hard way...
