Can someone calculate data for megane IR key using carprog from label: ST58R
regards
regards
Send vehicle type
hi. pin code
pin 9461 ....
Reality of life :
1:Never argue with an idiot, he will drag you down to his level and beat you with experience
2:It’s hard to argue with a genius. It’s impossible to argue with an idiot
3:Jealousy is a sign of inferiority
4:Everyone lies
How much rubbish you leave behind, so much rubbish someone will have to read, or maybe you yourself
If you like to read garbage, don't slow down, just speed up
rafal (8th April, 2019)
I do not need a PIN code, I need to generate eeprom for motorola hc05k3 in the key.
I generated two eeprom data for key 1 and 2 using the very old version of carprog:
50 06 C3 42 94 1F 80 02 6F BD 3F 59 00 00 00 00
56 45 B8 1E 94 1F 80 02 76 FC 34 2D 00 00 00 00
but the key after writing does not work correctly, stops sending IR and after pressing the button red LED lights about 2 seconds - too long.
(when I write eeprom from any used key works correctly. The used keys that I have for sure works correctly. I tested this two eeprom date on 5 different keys)
The problem is the old version of my carprog and incorrectly generated data.
I need to generate eeprom data key from label: ST58R on a newer version carprog where will it be "MEGANE KEY v0.2" (as shown in the photo in the attachmentcarprog.jpg)
as shown in the photo in the attachmentas shown in the photo in the attachment
