Results 1 to 12 of 12
Hybrid View
    Nov 2013
    the other side
    Default SMART FOFOUR DRIVE AUTHORIZATION FAULT HELP
    Hi all , smart fofour been standing with dead battery long and getting drive authorizaton fault in meg
    fault code p0513
    vin is wme4540322b042172
    how to get code and where to put it ? using star diagnostic
    Nov 2013
    the other side
    bump , please help
    ekas's Avatar
    Jan 2016
    Kyrgyzstan
    Best of all use smart fix for Das
  4. The Following User Says Thank You to ekas For This Useful Post:
    Ebie (11th April, 2019)
    Nov 2013
    the other side
    ANY MORE INFO
  6. #5
    Oct 2017
    Use Xentry to sync MEG with SAM and all will be fine.
  7. The Following User Says Thank You to autodiagdoctor For This Useful Post:
  8. #6
    Nov 2013
    the other side
    Ii have xentry , it need code from vin
  9. #7
    ekas's Avatar
    Jan 2016
    Kyrgyzstan
    What xentry version do you use?
  10. #8
    Nov 2013
    the other side
    07/2015 VERSION
  11. #9
    ekas's Avatar
    Jan 2016
    Kyrgyzstan
    try this, I think will help you
  12. The Following User Says Thank You to ekas For This Useful Post:
    Ebie (12th April, 2019)
  13. #10
    immokill's Avatar
    Jun 2009
    UNIVERSE
    WHY PASSWORD ????
    here is file originaly posted here on DK BY USER svrecar
    If you have das up to 2011...use this calc and fix for das....
    SmartCalc+log fix.rar
    If you are using das newer than 2011 then copy this file to c:\programme\das\smart
    and there is no need to enter code, just continue with f2.
    csdsmart_das.rar
    Here to HELP!
  14. The Following 2 Users Say Thank You to immokill For This Useful Post:
    Ebie (16th April, 2019), fliper (13th August, 2019)
  15. #11
    Nov 2013
    the other side
    CANT SEEM TO DOWN SMART CALC
  16. #12
    Nov 2013
    the other side
    worked like a boss immokill
