Results 1 to 15 of 28
    tmkz's Avatar
    Sep 2010
    PL
    Default Passat b6 adapting steering lock on
    Hi Passat B6, i try adapt new ESL from dealer.
    I have a PIN for car and it looks good, Engine ECU accepting it, Comfort Module same pin code.
    but when going into 25-Immobilizer and trying:
    1. Adaptations, channel 0 read, save 0
    2. Security access - PIN ......
    there is a Error 22: Requiment not met or wrong sequence and can't adapt new ESL.
    What am i doing wrong?
    i wait 255min LOCK TIME IMMO, now LOCK TIME 0.
    thanks!
    brend's Avatar
    Oct 2015
    Same where
    Im long time ago have same trable with esl adaptation and I have sulution for this...........
    Put original esl back then turn ignition on go ccm put login ,after login successfully done don't turn ignition off and replace esl by new one and go adaptation !
    With vcds its work!Tryed many times!
  3. The Following 5 Users Say Thank You to brend For This Useful Post:
    Andreastech81 (19th September, 2023), nenadgorgi (10th April, 2019), rafal (10th April, 2019), tepSIJA (21st February, 2021), xseva (25th September, 2019)
    tmkz's Avatar
    Sep 2010
    PL
    when i put original esl no ignition... communication ok, pin, error 22, maybe corrupted eeprom comfort?
    Sep 2013
    garage
    if you remove cover ... there is a mecanic lock on elv ...remove cover an make elv to work one time to do your job
    brend's Avatar
    Oct 2015
    Same where
    Wait securyti time and try agane.
    Quote Originally Posted by tmkz View Post
    tmkz's Avatar
    Sep 2010
    PL
    ok, thanks, but when i calculate cs my program say ERROR DECODING CS.... maybe my comfort is bad
    I wait 255 old elv, new elv, error 22. when i write pin 28234 lock time 40.
    tmkz's Avatar
    Sep 2010
    PL
    need pin, cs.
    tunelab's Avatar
    Feb 2019
    VIN:WVWZZZ3CZ6E021269
    Immo ID:VWZCZ000000000
    CS:1386B79A270D6
    MAC:54722913
    PIN:28234
    Power Class:FE
    ELV:BDAC
    CCM Status:06
    Key Count:02
    Key1:9532119F
    Key2:A07FC5CF
  10. The Following User Says Thank You to tunelab For This Useful Post:
    tmkz (11th April, 2019)
  11. #9
    tmkz's Avatar
    Sep 2010
    PL
    now pin code accept, but chanel 51 when i write old pin..... wait.... NOT OK
  12. #10
    tmkz's Avatar
    Sep 2010
    PL
    my car start.....but escl not work....
  13. #11
    tmkz's Avatar
    Sep 2010
    PL
    solved, thanks all, brend your procedure is OK, tunelab pin cs ok, thanks!
  14. The Following User Says Thank You to tmkz For This Useful Post:
    brend (12th April, 2019)
  15. #12
    Oct 2014
    Netherlands
    Yes, always decrypt CCM by powering it with old ELV attached.
    (Only if your old ELV is completely dead or missing then you have a bigger problem ...)
  16. The Following 2 Users Say Thank You to H2Deetoo For This Useful Post:
    brend (12th April, 2019), tmkz (12th April, 2019)
  17. #13
    brend's Avatar
    Oct 2015
    Same where
    Press magic button for more power.........
  18. The Following 3 Users Say Thank You to brend For This Useful Post:
    electrohicham (7th June, 2023), Raould (30th July, 2024), tmkz (12th April, 2019)
  19. #14
    Mar 2019
    Is it then possible to adapt new steering lock without old one? I do not have old and need adapt new...
  20. #15
    dimon9555's Avatar
    Oct 2012
    Belarus
    Quote Originally Posted by TESTASTRETTA View Post
    no problem
