Results 1 to 4 of 4
    Nov 2016
    spain
    Default XHORSE Mini Condor V5.2.6 Problem
    VERSION 5.2.6
    I have bug when i try to cut Fiat SIP22 or Peugeot NE78 blades. The machine go crazy, some times cut more depth, and destroy the milling cutter hitting the jaw. I need power off the machine and try again. i must see mindfully and stop machine before this happen.
    <span style="color:#ffff00;"><font size="3"><span style="font-family:arial black;">
    Jan 2017
    USA ����
    what the ~~~~ is that...............
    what kind of power are you supplying to the machine?
    it sounds slow
    i see your in spain what sort of power comes out of your wall?
    Nov 2016
    spain
    Quote Originally Posted by sleepyrz View Post
    it sounds slow
    the machine go perfectly, only have problems with fiat and peugeot NE78
    Jan 2018
    CA, USA
    mine did same issue. i ruin many cutters when this happens and also marking on clamp. now when i use side A i always watch, if i see cutter move above blade i immediately turn off machine. no issues since updating to 5.3.2 but im worried on updating again because updates always causing problems and tech support is no help. they say machine needs to be cleaned and i always clean mine. excuses excuses.
