Results 1 to 5 of 5
    Oct 2018
    Northern Ireland
    Default 2015 Renault Captur
    Been asked to do a spare card for this Renault but existing card is starting car but om dash display says card not recognised. Using MVP but worried if cards deleted and go to add again they won’t go in.
    Is this a common thing or should I avoid going to this one ?
    Thanks in advance 👍🏻
    Feb 2019
    Quote Originally Posted by Jimmy07 View Post
    Thanks in advance 
    starting car .... or not recognised ?
    just resoldering coil , and add new card after repair old
  3. The Following User Says Thank You to R2D2R2 For This Useful Post:
    Jimmy07 (12th April, 2019)
    rob h's Avatar
    May 2011
    Display show, that the keyless function is faulty?!
    Inserting it in the hfm slot will start car.
    These cards are not so expensive, make sure to get the correct type, with or without keyless.
    Some sellers have nice onces with chrome logo.
  5. The Following User Says Thank You to rob h For This Useful Post:
  6. #4
    Oct 2018
    Northern Ireland
    Thanks for replys just wanted to know if it was an issue on these models before deleting all keys to add new key.
    It’s not proxy key it’s slot type
    Car starts ok but display on dash saying key not recognised. If it’s a key issue no big deal. Yes can get decent cards at the right money and easy to programme in.
    Thanks again everyone 👍🏻👍🏻
    scotland clydebank
    Also tell customer is original key wont be recognised as this often happen on Renault tell him not to expect 2 working
    Key cards as the one is working now 90 percent won't go back in.
  8. The Following User Says Thank You to godfathertre For This Useful Post:
