    Codekuba's Avatar
    Aug 2018
    Default Vvdi key tool EU version
    Hello
    I Have problem with clone id46 (pcf7946)
    Fiat panda 2013 year
    I read transporder
    Copy with sniff vvdi key tool
    Clone id46 "good" on display
    Car dont start
    Only original key
    I try with 3 tp and not results
    Thanks and regards
    HELP == thanks + reputation
    Jan 2017
    USA ����
    You check transponder to see if data is the same??
    Codekuba's Avatar
    Aug 2018
    Yes, data od this same
    scotland clydebank
    Have you tried with transponder out of key next to ariel ignition sometimes fiat
    Cloned key do not work where well
    Due to weak signal from transponder
    If you had jma trs5000 evo could have checked this have you got handybaby try to clone with that.
    Codekuba's Avatar
    Aug 2018
    Quote Originally Posted by godfathertre View Post
    Yes, I try without key and not work...
    I clone this same key in fiat 500 latest week and work good
    p1et's Avatar
    Oct 2013
    Sometimes that happen, normal thing. Just clone on TPX and take money.
