Results 1 to 2 of 2
    Newbie renzor's Avatar
    Mar 2014
    RO
    Default Dacia Logan 1.5dci 2010 DPF OFF - please help with my file
    Hello, may you please check my DPF OFF file?
    The car still has the ignition coil warning light on, when checked with fault reader there is no error stored, but it dissapears when you erase DTCs and reappears after driving.
    I think I forgot to delete the DTC before reading the file, can this be a problem?
    Thank you.
    I hope i won`t blow my engine.
    Feb 2019
    Default DACIA LOGAN DPF OFF
    Hi, try this file DPF OFF
    Pass=thanks+rep.
    Read PM
