if it can help you .......
[SIZE=3][I][FONT=impact][COLOR=#ffd700]PUSH THANKS AND REP IF I HELPED YOU !!!!!!
here is my connection for X-Prog
https://www.digital-kaos.co.uk/forum...t=read+xc2336a
Thank you for your attention.
Thanks adding some info below
Thanks, I can't read it the way you connected on xprog
Also I'm attaching vvdi prog diagram maybe could explain what it mean (must be on high) and (must be low)
on 38,39,40 pins?
Thank you
I'm will borrow xprog from a friend and try read it with it and see what happens then. Or I'm doing something wrong...
I'll keep you updated.
Ok, just an update. I definitely fried the module by that much soldering etc. But I was able to read some of it with x-prog.
Anyway got another one coming from lkq, see if that one has crash data inside. Thanks everyone
