Techstream 8.20.019 pass code free do it.
I myself even programmed the 2018 corolla. on Corolla from 2014 to 2018 there is the same protection 128 bit H chip. Just choose Corolla 2014 and program the key.
2018 new tis “classic” still works
2019 Corolla newest system New Seed calculator New Tis.
I tried it, but this version does not work for NA prius 20 2007, Tis requires Pass-Code when trying to reset the smartkey ecu. Maybe I installed techstream incorrectly?
when I tried to install at the beginning, the application kept crashing with the mainMenu appcrash error in ntdll.dll Win7 32,
then I installed the usual techstream version 8.20.019 and replaced the working folder "Toyota Diagnostics" in the C:\Programm files with the folder from the archive provided by the respected hackgsm. The application started, but the random Pass-Code does not accept.
Is it possible that the matter is in the driver version for MiniVci cable? I have v2.6.00 installed.
Or did I not install Thechstriam correctly?
P.m. my friend
Press Thanks Button And Reput If i Help
mojomojo (12th December, 2020)
