hi all
And you lost sync with ecu while flashing with the kess device. The boy did not put the key in the writing and the car does not start. I see in eeprom from ecu that the offset with keys is empty. I tried all the possibilities with the eeprom virgin attempt to add the key coder galletto, unfortunately without success. I tried to enter the key contents manually with eeprom without success. I attach the immo box and ecu dump. will anyone help, any ideas ?? I am tired of this car ....
Reality of life :
1:Never argue with an idiot, he will pull you down to his level and overcome you with experience
2:Envy is the confession of inferiority
3:Everyone lies
How much trash you leave behind so much trash someone will have to read or maybe you yourself
If you like reading garbage, don't slow down, just speed it up
post ecu info............all
need help
now my goal is to buy xp-005
who will help?
better search for set ECU and Immo amd write your keys in immo dump or make new, or find eeprom dump from same ECU and try to make it virgin and recode
i have this car running well i will post immo and ecu dump
I have one very good solution
Tested 2 days ago
Plug FGTECH V54
In option of Suzuki you need KEYMAKER
Press ok and enjoy
cfgebel (20th April, 2019)
