2005 Nissan Micra K12 all keys lost
Page 1 of 2 12 LastLast
Results 1 to 15 of 16
    Jul 2016
    Default 2005 Nissan Micra K12 all keys lost
    Hi Dear
    I have Nissan Micra K12 2005 all keys lost the original key was with remote 2 button and ID 46.
    I trying to program key by T300 with glove box pin code 12 code but not program at all.
    Can you please help me to program the car key with which tool use to program and the chip type.
    Pictures of glovebox , BCM lable , BCM plugs and original key picture
    But we don't have original key just need to program chip with normal key.
    Sent from my BV9600Pro using Tapatalk
    newone's Avatar
    Oct 2016
    you must program remote key,car does not accept pcf7936
    Jul 2016
    Quote Originally Posted by newone View Post
    Remote key with pcf7946 can be unlocked I have used one
    P&D's Avatar
    May 2010
    Nissan Micra 2005 can be 2 keys types
    Key 2 .https://www.nwkeys.co.uk/Product/nis...icra-etc-03-12
    key 1 which you have in the 1st post
    key 1
    Nissan Micra K12 28268AX600 11.2002-05.2005
    Nissan Miicra K12 28268AX61A 07.2006-2010 (end of K12 production)
    Nissan Note E11 28268AX61A 01.2006-12.2008
    Nissan Pathfinder 01.2005-09.2006 (without intelligent key system)
    Nissan Qashqai J10 28268AX61A 12.2006-01.2010
    Jul 2016
    Quote Originally Posted by P&D View Post
    key 1
    My car is key 1 not keyless one can program pcf7936 to run car or need pcf7946 to work
    castin's Avatar
    Oct 2015
    Poland
    Meybe Tango add pcf7936, but by obd must use pcf7946. Im learn key by use sbb and pin code, but remote not work. Im try use different precode - no succes. Car start ok.
    Top Poster rojhat's Avatar
    Sep 2015
    france
    Quote Originally Posted by mlwila View Post
    hi just replace 7946 new and precode it . finish
    Envoyé de mon SM-A605FN en utilisant Tapatalk
    Jul 2016
    Quote Originally Posted by castin View Post
    I am try to read eeprom 95080 on BCM and write key with tango but car not start and the light security still flashing.
    So how can make the key without having the original key
    P&D's Avatar
    May 2010
    As rojhat says
    hi just replace 7946 new and precode it . then program to car
    Pre code in Zedbull clone software & Effi
    Feb 2013
    you must use pcf7946. tango make pcf7936 but car can't start. with remote no problems
    Wysłane z mojego SM-G920F przy użyciu Tapatalka
  11. #11
    Jul 2016
    Quote Originally Posted by swq123 View Post
    Can I use the NB remote for vvdi key tool with pcf and generate the chip and remote as well can be programmed
  12. #12
    Jul 2016
    I mean this one can use it
  13. #13
    Jul 2016
    This remote can be programmed for the car
  14. #14
    newone's Avatar
    Oct 2016
    yes,if you use nb remote and program from obd everything will work ok
  15. The Following User Says Thank You to newone For This Useful Post:
    mlwila (20th April, 2019)
  16. #15
    Jul 2016
    Can program it with tango also
