Hello, your CAS read not OK
ECU ISN is E0 1F
ECU ISN is E0 1F
SA VEROM U BOGA, SLOBODA ILI SMRT
with the r70 I've been reading the cas and it's all normal
has eeprom and flesh file
this isn softwer gives me the kcas isn 3C 6A
can you try to type in the ECU?
automatic transmission is
Try this dump
Make sync after prog
semir1978 (20th April, 2019)
sutra probam
hbala
Bez brige brate moj
Javi mi obavezno, ili pokusavamo drugo
moze li tvoj br tel da se cujemo viber isl.
Reality of life :
1:Never argue with an idiot, he will pull you down to his level and overcome you with experience
2:Envy is the confession of inferiority
3:Everyone lies
How much trash you leave behind so much trash someone will have to read or maybe you yourself
If you like reading garbage, don't slow down, just speed it up
<---- Coin of the Realm.
Reality of life :
3:Everyone lies
ok cas is black cas3 but platine is cas2 cpu mask 0L01Y
wath is next step
obdstar 300dp wont read isn
