Results 1 to 7 of 7
    Jun 2017
    Barcelona / Spain
    Default Flash bsi jc citroen c4
    Hello
    I need flash file for the jc bsi citroen c4 .Will use fvdi for writing.
    966405908001
    BSI04EV K04-00 100907
    V05.01
    BOOT 28120836-4
    HARD 28119248-3B
    Gracias !
    Oct 2015
    LV
    Need software signature for correct flash file. Please write it here!
    May 2016
    Plik dla Ciebie.
  4. The Following User Says Thank You to naprawa5 For This Useful Post:
    skens (23rd April, 2019)
    Jun 2017
    Barcelona / Spain
    Hello
    I can not connect to the original bsi. Base plate shattered. I have only been able to read eprom with the upa i have the pin code.The flash is an EasyCan4f ... i do not have datasheet for this.I have a scrap bsi with the same reference but hard is 28119248-3C and the original is 28119248 -3B.I've configured with pin the vin and the transporter and the car starts but does not detect automatic gearbox and windows do not work etc ... I am willing to try several flash
    Jun 2017
    Barcelona / Spain
    Thank you naprawa5 I'll prove it.
    Jun 2017
    Barcelona / Spain
    Default Need flash
    Hello people. It is possible to know the flash version of my bsi by the eprom file.The c4 is still not working. The eprom is ok.I have vin and pin but but I do not know the flash version. Gracias
    Jun 2017
    Barcelona / Spain
    Hello
    Solved
    I solved it by desoldering the flash of the old bsi and soldering it in the new bsi.The flash version is 7B6F.
    Thank you all
