Results 1 to 7 of 7
    Oct 2018
    Default BMW F10 535i crash data clear file, please help
    If someone can help with ACSM airbag module crash data reset.
    PN:
    6577 9239985-01
    ACM 618307400E
    BMW 31923985012
    Here is the original dump from the MAC7241VAF64
    Jan 2019
    usualy its enought to delete all errors and reset the ecu
    ASCM's Avatar
    Oct 2018
    WHICH TOOL U USED TO READ THAT?
    kazoula55's Avatar
    Sep 2012
    Error file size
    READ AGAIN
  5. The Following User Says Thank You to kazoula55 For This Useful Post:
    dannyx5321 (26th April, 2019)
  6. #5
    Oct 2018
    Xprog box.......................
  7. #6
    Oct 2018
    Quote Originally Posted by kazoula55 View Post
    Error file size
    READ AGAIN
    File is good, double checked. I got already a clear dump from a member on another forum, thanks anyways.
  8. #7
    Oct 2018
    Quote Originally Posted by camouflaged View Post
    NOT if you have three crash faults, in which case you either have to replace ACSM module or clear dump file
