Results 1 to 15 of 22
    V.I.P. Member ^^TommyTee's Avatar
    In a Skyscraper On Planet Earth With my Pet Snake
    Default A Suggestion what do yall think?
    Hi all
    I would like too see a Electronics Section in here
    with subsections ie.. components... pcb,s etc etc
    any chance of this ?
    Please be aware all my posts and associated links are purley for educational purposes only ... i will not be held responsable if you use any of this material or links whatsoever its at your own risk!!
    I do not condone any illeigal use of any information contained within.
    No1 Automotive Contributor ? BOLLOX
    PEOPLE CALL YOU A TWAT !!!
    Greetingz too 0ptik and the TRUE
    Automotive RSE Crew
    V.I.P. Member mickydibble's Avatar
    Nov 2008
    modsvilla
    Think it is a good idea very interested
    Administrator
    Devilfish's Avatar
    Feb 2008
    /cdk
    An interesting idea.
    I would like to see what other people think though.
    Thanks for the suggestion.
    Retired Sat TV Addict
    .: JaCkPoT :.'s Avatar
    Aug 2008
    var/tuxbox/plugins
    go for it.
    Read the Rules here; they apply to EveryOne.
    __________________________________________________
    DM800s HD
    Openbox S10
    TM500
    DM500s
    90cm FortecStar dish
    Technomate 2300 motor powered by UsalS
    V.I.P. Member chroma's Avatar
    Feb 2009
    Just outside of Glasgow
    Id love to see this.
    He who laughs last thinks slowest.
    DK Veteran tomhick024's Avatar
    Between a Rock and a Hard Place
    Def would be interesting and would be a busy section I would think!!!!
    Whatever!!
    Bulld0g's Avatar
    Apr 2008
    Liverpool
    Well like most things, i know ~~~~ all but i think it would be a good addition and if you want to learn theres no better place than here
    Quote Originally Posted by Bulld0g View Post
    same here bd
    im very interested in learning electronics programming
    schematics pcbs
    i beleive this would be a very active part of the site
    very grateful for all your comments THANKYOU
    lets see if this can be made possible
    i for one will be a regular contributor too this
    im very keen too learn
    regards Tommy
    The Best Site Around ....Potential is infinate!
    no bullshit ...all sharing all caring my kind of people .....
    Automotive RSE Crew
    cunny's Avatar
    Jan 2009
    The Shoutbox
    I think this is a great idea, dont know allot about electronics so would like this secion, maybe some guides on things, looking forward to this.
    Aug 2008
    var/tuxbox/plugins
    Bump, i think we need a slightly more general opinion.
    DM800s HD
    Openbox S10
    TM500
    DM500s
    Mar 2008
    I think the electronics section would be a waste, just like the linux that never took off.
    What are guys going topost in this section where u can get R45 cheap etc, Am sure all electronics stuff will e cover in sections already on forum, well maybe apart the rabbit,.... You know what i mean i have issue whith tv i put in there, i have issue with sat its there.
    As for a 14 year old to bump it ( you still 14 ) well if ur anything like my 14 year old its in bits , and all comfy bits are in bin .
    http://www.resistor-color-code.com/color-code-chart
    theres a resistor chart for those that want to start, if stuck for parts go to local maplins, or radio shack
    Newbie prutserjo's Avatar
    Belgie
    I'm very interest in repair hardware von PC, TFT and LCD monitors, autodiagnose, and special : faults, results and schematic to make it self
    gr prutserjo
  13. #13
    Feb 2009
    Quote Originally Posted by gazz10 View Post
    Resistor color code chart
    Off the top of my head, things i could post are:
    Basic:
    Soldering guides (tips on tinning, desoldering etc)
    PCB Fab guid, tips on acid etching and UV etching
    Theory rundown, What components like transistors, resistors, diodes, capacitors are for and how to spot them on commercial gear. How to use multimeters, ocilloscopes etc.
    SMD work.
    Advanced:
    Schematics for boards (most of my schematics are for HAM/CB/PLL work) however im sure more people will have schematics for commercial boards, like dreamboxes, dboxes, starviews etc.
    Projects, like custom built valve amps (pull push amplifiers) simple radios (transmitters and recievers) diagnostic boards...
    Antennas (to boost wifi like cantennas, helix, double quads, parabolics) would work for Satellite for instance.
    Linear amplifiers (for preamping signals like cable, satellite, radio, wifi etc)
    Attenuator boards and noise suppressors.
    MIDI interfaces.
    Even down to stupid, pointless, useless stuff that just looks like it would be fun to build and try out.
    The list is endless and as varied as users could concieve.
    Ive not done any real electronics work or projects in years, not since my radio days, but theres still loads that could be contributed thats either too general or specific to be contributed in any other sub forum.
    Even if it goes down in flames, so what? atleast it was an attempt, its better to have tried and flunked it than to always wonder what if.
  14. #14
    Administrator
    Devilfish's Avatar
    Feb 2008
    /cdk
    So what could we have in terms of section headings?
    Analog
    Digital
    etc?
    Or just one section to start with?
  15. #15
    V.I.P. Member SatSearching's Avatar
    Apr 2008
    /tuxbox/enigma/src
    How about something along the lines of "home domestic electronics" to start with covering a wide range to judge interest?
    Good ideas from chroma though, but add to this the idea of repair tips for brown and white goods in the home?
    SS
