emu elv avdi is neccesary update firmware for w246.contact you dealer or abritus.
Did anyone succesfully programmed a used ELV on this car ?
W246 2014 , its still FBS3
Emulator works no problem, but i cannot activate a personalised elv to the ezs
i tried 3 different elv.. used avdi and vvdi mb for renewing and programming.
thanks in advance
If you use Novel ESL emulator will work perfect for W246 and W117 as well
you can use emulator for xhorse and cgdi and thegend programed it like w204 works fine
W246 is diferent elv not w204
Yes, i have successfully made 3 of these jobs using a previously used ESL from breakers yard, renewing it and then personalising it to another car.
If you wish to use a renewed ESL for these W246/176 cars then it must be personalised via the EZS IR portal in the car. (Blue Key Method same as dealer does it)
As far as i am aware there is only the one tool that currently supports the personalisation of these ESL via the EZS IR Portal (Extreme MB Tool) it uses the same protocol as the dealers Blue workshop Key. This is the only way that a renewed W246/176 ESL will get activated and work again.
The old methods we used in the past to personalise a renewed W204 ESL on the bench via K-line do not work on these later ESL, they will personalise ok, but will not activate when we insert a working key as the old W204 ESL did ...
However, there is no problem using an emulator on these W246/176 cars.
I use these emulators now for all FBS3 ESL jobs,
Here is some additional info on how to use these emulators with W176/246 cars
Jonny
autodiagdoctor (24th April, 2019), babeh (23rd October, 2021), clauberty (21st May, 2020), ficho (23rd April, 2019), hack_dd (24th April, 2019), Hayssam1 (10th June, 2019), Jimalex (24th April, 2019), kitachu (20th July, 2023), madaxe (28th April, 2019), Mario3 (24th April, 2019), mercis (24th April, 2019), qwojtus (24th April, 2019), rola1971 (25th April, 2019), Sasika (26th April, 2019), Shakeelbhugeloo (14th December, 2021), skens (13th March, 2020)
jonny r (24th April, 2019)
Hi Mario3,
I had the same problem over a year ago, emu works fine but no way to program a used elv, as Jonny r stated this can be done but initialization must be taken in car directly:
part from Jonny r message:
regards
A used ELV with AVDI work fine.
I make it today "FBS3".
Greeting.
