DTC off only is not enough.
Hello, I need help in correct removal of DTC P2512 in ECU EDC16C2 - Mercedes Viano 2.2 CDI 150HP. After inserting 0 in the address 0CA916, the error tester can not see but the car enters emergency mode after 3-4 trips of the engine. Does anyone know the solution to this problem?
kinketotua (23rd April, 2019), krokodyl30 (23rd April, 2019), stanislav georgiev (23rd April, 2019)
Yes, I know. The problem is that I do not know what else to change in the file so that the car does not fall into the emergency mode.
Write this file
The problem is still not resolved.
write file
krokodyl30 (24th April, 2019)
Thanks, I will test and report!
It is still not good. On the plugged P2512 throttle plug and after a few starts the emergency mode. On the unplugged P2529 throttle plug and the emergency mode permanently.
easy job, turn off maps with throttle ( NO DTC OFF + LIMP )and disconnect plug.
FILE SERVICE
krokodyl30 (25th April, 2019)
Here, test a manual solution
krokodyl30 (25th April, 2019), pike (25th April, 2019)
Colleague stanislav georgiev correctly solved my problem.Auto works well, does not enter into the emergency mode, no errors! After the test drive there is still an error EGR but it's rather unrelated to the topic. Thank you all for your interest in my topic!
stanislav georgiev (25th April, 2019)
