Results 1 to 8 of 8
    May 2009
    Default Fiat Doblo MJD8F3 DPF & EGR OFF help
    Hello
    I was trying to dpf & egr off solution on Fiat DobloMJD8F3 MJ8F3HW1FP 2442D330. I tried with some tools with different results.
    DPF & EGR 2017.05 got limp mode after about 10km
    ASC DPF & EGR 3.0 (02-2016), work perfect, but after about 200km I got DTC P2002 and P1564, I can deleted with tool (DTC REMOVER) but still limited at 3.000rpm.
    I was reading this ECU can be done with any tool, and need to be manually, but I can't find the map for this ecu or the hex sequence to find manually in winols.
    any help will be really appreciated.
    PD: I reset dpf values with FES before write the file.
    Dietrich's Avatar
    Oct 2017
    EUROPE
    If you are making like this, reset ash level with fes on ori file, disconnect dif.pressure sensor+temperature sensors on dpf, kill dtc and use aes remover.
    pike's Avatar
    Sep 2013
    or need working DPF EGR off solution made by hand.
    HIC's Avatar
    Apr 2010
    Still need mod file ?
    May 2009
    after bought a mod file from experienced user (manually by winols), we detected that the problem are in the RESET DPF VALUES (dpf replace step before write). At the first time i was using FES 3.9 but I notice that FES don't set to 0 of the clogging level, neither Distance travelled with dpf warning indicator ON. So, today I tried with LAUNCH FIAT V35 (with ORI FILE & mod file) without result, I got a OPERATION FAILED and FORCE REGEN is causing a failure.
    anyone know how to reset the values?.
    May 2009
    Quote Originally Posted by pike View Post
    thank you captain obvious for you invaluable help in the community.
    pike's Avatar
    Sep 2013
    what soot value now?
    Newbie Mk5TDI's Avatar
    Mar 2019
    Sicily
    Quote Originally Posted by bluekrash View Post
    Hello
    passw PM test and report please
    : Danza:
