If you are making like this, reset ash level with fes on ori file, disconnect dif.pressure sensor+temperature sensors on dpf, kill dtc and use aes remover.
Hello
I was trying to dpf & egr off solution on Fiat DobloMJD8F3 MJ8F3HW1FP 2442D330. I tried with some tools with different results.
DPF & EGR 2017.05 got limp mode after about 10km
ASC DPF & EGR 3.0 (02-2016), work perfect, but after about 200km I got DTC P2002 and P1564, I can deleted with tool (DTC REMOVER) but still limited at 3.000rpm.
I was reading this ECU can be done with any tool, and need to be manually, but I can't find the map for this ecu or the hex sequence to find manually in winols.
any help will be really appreciated.
PD: I reset dpf values with FES before write the file.
or need working DPF EGR off solution made by hand.
Still need mod file ?
after bought a mod file from experienced user (manually by winols), we detected that the problem are in the RESET DPF VALUES (dpf replace step before write). At the first time i was using FES 3.9 but I notice that FES don't set to 0 of the clogging level, neither Distance travelled with dpf warning indicator ON. So, today I tried with LAUNCH FIAT V35 (with ORI FILE & mod file) without result, I got a OPERATION FAILED and FORCE REGEN is causing a failure.
anyone know how to reset the values?.
what soot value now?
