Tool died after few test,i guess is a bad clone.As I saw I'm not the only one who has this.
Real engines don't need forced induction
Who needs a turbo when you have a stupidly quick naturally aspirated engine?
What power supply did you use with the tool?
"thanks" if i helped you is really appreciated
KTM Flash is PCM Flash
I tested PCM fLASH Klone and PCM Flash orginal.
Moduel 58 and 62 work fine(tested only 58 and 62)
Thinking about buying it but after reading negative reviews on here kinda scares me. Did anyone have a better luck than NASTASE?
gege974 (31st March, 2020)
I have it. I bought it because I needed it for SID208 PSA, after I got the tool I tried to do the job, but at first, I couldn't read password... The problem was the power supply, it is better to use good power supply, or just connect the tool to good battery... After this I managed successfully read/write this ECU.
Also did successful read/write to VW EDC17C46, Volvo EDC17CP22 or EDC17CP48 (don't remember which one, because one of them I couldn't make reading)...
abderr16 (25th May, 2020), danielif (15th May, 2020), looneyman (1st September, 2019), pulsar2000 (23rd May, 2020), RIMKACHIP (28th April, 2021)
drewdom (2nd September, 2019)
Today did tests on VW EDC17CP04 - everything ok, did writing few times without any problems
blackpirate (21st September, 2019)
bmw(f20) med work
fiat doblo-ducato edc17 work
peugeot sid208 work
transit sid208 -boot- work
It works very well i test today, Perfect Seat Leon 1.6 tdi same ecu
after 12 tears on this job i have spent lot of money for chinese tools .......shit tools...the last 3 years i use original tools.KTAG genuine beeprog genuine i/o terminal......etc..
don't spent your money on chinese tools....do many job's,but if the tool for one time make mistake .....when will pay a lot money to fix that mistake...
it's only my opinion
regard's
real shit, ecu BOSCH_MED17.5.21_IROM_TC1782_EGPT_VAG killed while writing. Not posible boot anymore than with x17, ktag, magpro..
hesham10 (8th January, 2021)
I tested a Chinese clone
EDC17C84 1.6DCI Renault Nissan works ok chip tuning - checksums ok
EMS3155 Continental Qashqai 2017 1.2 TCE works ok ecu cloning
SID310 Mercedes A W176 1.6 CDI 2017 works ok ecu cloning
adrianojeminaj9 (18th November, 2020), RIMKACHIP (28th April, 2021)
