Page 3 of 6 FirstFirst 123456 LastLast
Results 31 to 45 of 82
  1. #31
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    Quote Originally Posted by waldigsi View Post
    I tested a Chinese clone
    SID310 Mercedes A W176 1.6 CDI 2017 works ok ecu cloning
    can you help us...?
    which sw modul you used from this chinese cracked sw for cloning a SID310....?
  2. #32
    Dec 2018
    Europe
    He certainly used module 71
    Microcontroller: Tricore IROM TC1791
    EEPROM: inside microprocessor
  3. The Following User Says Thank You to nagold For This Useful Post:
    gia (24th March, 2021)
  4. #33
    Feb 2011
    Quote Originally Posted by nagold View Post
    yes exactly, but I also used the uhds smok to read the password, with the password pcmflach read and wrote sid310
  5. #34
    figani's Avatar
    Feb 2018
    With module 71...?
    It seems here are a lot of sellers of this tool and make some kind of advertising...
    71 is for Bosch...
    Sid 310 is what...?
  6. #35
    figani's Avatar
    Feb 2018
    So with Bosch module 71, you can read whole tricore units...?
    If you read by other tool pw...?
  7. #36
    Dec 2018
    I read/write an edc17c60 from peugeot 308...
    Now have a problem with TPROT, after drive some time, car don't start again...
    I read File need to be patched.. But I can't do this... Some one can help me?
  8. The Following User Says Thank You to SamuelRib For This Useful Post:
    abdonete (21st May, 2021)
  9. #37
    figani's Avatar
    Feb 2018
    Quote Originally Posted by SamuelRib View Post
    this problem is solved now by oleg pcm with update 1.2.1...
    maybe chinese reseller make also an update...
  10. #38
    Dec 2018
    Quote Originally Posted by figani View Post
    improved in the original product!
    I hope the hacking of the Chinese will never be able to be updated again. and pcm improved the protection of its software.
  11. The Following User Says Thank You to Catalizator For This Useful Post:
    bauvaisis (11th June, 2020)
  12. #39
    credoline's Avatar
    Србија
    Chinese now offer for KTM bench version 1.199 which cost 247e and version 1.20 which cost 237e. I am confused. Why new version is cheaper than older? How that? Anyone have ver 1.20?
  13. #40
    Oct 2016
    could someone help me how to read password from Ford Transit SID208?
    I tried with two different ECU no result while my KTAG read it no problem.
    I used the same connection diagram and power supply on booth tool and only KTAG read them.
    UNI
  14. #41
    Dec 2018
    the password is read when the unit is connected to the car or on a bench without boot pin
  15. #42
    figani's Avatar
    Feb 2018
    Quote Originally Posted by credoline View Post
    Chinese logic, maybe you can only understand it if you are a Chinese...
    Pozdrav...
  16. The Following User Says Thank You to figani For This Useful Post:
    credoline (15th November, 2020)
  17. #43
    Oct 2016
    EDC17C46 can not read with module 71. Others with luck?
  18. #44
    Oct 2016
    Quote Originally Posted by Milicija View Post
    I have it. I bought it because I needed it for SID208 PSA, after I got the tool I tried to do the job, but at first, I couldn't read password... The problem was the power supply, it is better to use good power supply, or just connect the tool to good battery... After this I managed successfully read/write this ECU.
    Also did successful read/write to VW EDC17C46, Volvo EDC17CP22 or EDC17CP48 (don't remember which one, because one of them I couldn't make reading)...
    edc17c46 with boot or bench?
    UNI
  19. #45
    Aug 2016
    will there be a way to read the password with ktm bench, will there be any connection diagram?
    Enviado desde mi SM-A505G mediante Tapatalk
