    korrni's Avatar
    UE
    Default Mercedes CLS W219 EDC16CP31 1037393838 DPF OFF please help
    Hello guys,
    Could you help me remove the dpf from a Mercedes W219 3.0CDI EDC16CP31?
    Thank you, guys, dump in attachment!
    joker01's Avatar
    Jan 2018
    dpf off no cks.......report
    [SIZE=3][I][FONT=impact][COLOR=#ffd700]PUSH THANKS AND REP IF I HELPED YOU !!!!!!
  3. The Following User Says Thank You to joker01 For This Useful Post:
    korrni (24th April, 2019)
    korrni's Avatar
    UE
    Quote Originally Posted by joker01 View Post
    Thank you, I wil try it and report!
    korrni's Avatar
    UE
    It is identical with the Universal DPF Remover Solution which already I have tried. The car runs well, but, when the engine gets hot, it starts to hardly smoke, like starting the regeneration process. Do you have a tested or manual solution? Thank you!
    Nov 2018
    Germany
    Default dpf off
    Quote Originally Posted by korrni View Post
    Hello guys,
    Disconnect dpf sensor
    pass PM
    regards
  7. The Following User Says Thank You to FlashTune For This Useful Post:
    korrni (25th April, 2019)
  8. #6
    korrni's Avatar
    UE
    Quote Originally Posted by FlashTune View Post
    pass PM
    regards
    Thank you, I will try and report!
