seems like a 1 3 4 1 3 2.
always a 4 cut
I will cut 134132 and see if where it bites and then file it or cut it.
Example. if it bites on the second position which has depth 3 you can file or cut with 2.
or use the tibbe to decode the barrel
I have 2 pictures, of a tibbe 6 cut key.
There is always a 4 cut, as far as i know.
Is there always a 1 cut in these aswell?
always a 4 cut
rob h (24th April, 2019)
For me is 100% - 1 2 4 1 3 2
Thanks, hoped to just send them the key.
I already cloned the transponder.
134132 gives me file down options,
Thank you guys
Sorry I just changed my answer
The difference between the first 2 cuts is small. Thats is also why i came to that code. 124132
send them 2 tibbie heads
124132
134132 - my money still on this one
BUt is defintly one of these 2
rob h (25th April, 2019)
also 124132 gives you best filing down on the second position because you can make from 2 --- 3 and not the other way around like i said above. My mistake
1 3 4 1 3 2
