Results 1 to 3 of 3
    Nov 2015
    west sussex
    Default Fiat Ducato dashboartd gauges
    Can any one help,i have the above dashboard (2008) with no analogue gauges working,according to the garage all was ok untill a flat battery.Battery was charged and vehicle started,all warning lights are ok and vehicle runs fine,just the gauges have failed,any ideas?
    TOINO's Avatar
    Jan 2012
    start by unplugging the battery and then charging the capacitors by making a short circuit with the two more and less cables disconnected from the battery connect the battery again and see if everything is returned, if it is still the same maybe something was corrupted in the dash file, then try to find a new dump for dash!
  3. The Following User Says Thank You to TOINO For This Useful Post:
    rodnro (26th April, 2019)
    Nov 2015
    west sussex
    Thanks Toino,i think your right,a new dump required.
