Results 1 to 2 of 2
    Feb 2010
    Serbia-Zrenjanin
    Default Ford fiesta semi automatic to manual transmision
    Hello
    I have Ford fiesta with semi automatic transmision ,
    easytronic is dead and some was remove easytronic control unit .I found 4 wires with can communication and I make bridges and
    now I have communication via diag and connection pcm and instrument cluster.How to reprogram pcm to manual transmision,I try with IDS 112
    without succes,try with forscan same
    Ecu is SID 804 5ws40142D-T 3S61-12A650-GD
    inside is eeprom93c56 and flash29f400,
    dumps are in rar
    Do I need to modify file in Dash???
    Feb 2010
    Serbia-Zrenjanin
    nobody have solution?
