barto41 (24th October, 2019)
Most likely that board goes to trash...
C boards are the worst..
hello
Have you the dump for my ?
are the boot dump for all rns 510 the same ?
regards Henk
here is complete set of dumps for all memories in continental rns510..
Hope this helps, if it does dont forget thanks.
1974 (30th November, 2020), alpntrb (8th December, 2020), armpower (6th May, 2019), barto41 (24th October, 2019), baygrozdan (10th August, 2023), bladeus86 (18th June, 2021), Boras (13th February, 2021), buddycz (3rd January, 2021), cavallotv (1st February, 2021), cheero (25th October, 2019), Dratex (26th April, 2022), DreamDancer (22nd May, 2019), EROS1 (15th April, 2020), henkgr (29th April, 2019), hesham10 (28th February, 2021), isavrseno (6th December, 2020), markogr (18th September, 2019), nawigorzow (24th December, 2020), Papiti56 (18th July, 2021), sandocan75 (18th May, 2019)
thank I try
It's from the b versie but I hope that it will work
regards
pleasure friend,
i know that when a b version is updated with new firmware the part number chages to C at the end..
hi, did you solve your problem with RNS510? I have the same problem with booting it.
Did you use all dumps from limitlesstuning?
no ,I will try it later
thanks ,i will try it later
You can also use the firmware witch dvd it will work just press right 2 buttoms upper ans the seput the same time and after 5 sec release the 2 and keep holding setup it works fine
