Results 1 to 8 of 8
    VeryFastSnail's Avatar
    Jan 2019
    Default ECU two injectors fail to open
    hello, I have this Opel Astra ecu (picture attached) and the problem is that it fails to send signal to injectors, two injectors works fine, and other are failing, one gives low signaling, and another is always opened. (testes with Oscilloscope). what could be the problem?
    If I helped you, feel free to drop me that sweet sweet +1 thank you.
    Oct 2018
    egypt
    did you try with another one and problem solved ? do you have same units known to be faulty (parts replacement) ? if yes open ecu and give clear pictures .
    wbr.
    Jan 2019
    The problem is that I do not have replacement unit. Tested wiring and injectors itself, both good. attaching pictures.
    Jan 2019
    New pic with heat sink removed, will draw diagram of it soon.
    Oct 2018
    egypt
    i think this ic near two yellow capacitors but not sure ... in last picture ... behind white connector not red connector ...
    wbr.
  6. The Following User Says Thank You to hesham10 For This Useful Post:
    VeryFastSnail (27th April, 2019)
    Jan 2019
    It's Delco 55199 chip injector controller. Do you think it's bad?
    Oct 2018
    egypt
    just try another one
    wbr.
    EU
    Injector driver 100%
    Sent from my iPhone using Tapatalk Pro
