Results 1 to 10 of 10
    super jumbe's Avatar
    Livingstone
    Default Audi A5 convertible 2011 ECU burnt help.
    Lads got in garage Audi A5 convertible 2011 with ECU burnt some one connected battery terminal wrong way round, I have new ECU from scrap yard and can not see 8 leg eeprom what’s the procedure to program the ECU is there virgin file or flash please advice.20190427_185631.jpg20190427_185631.jpg20190427_185645.jpg
    pepi's Avatar
    There is MED17 ECU and as we know there no 8 pin chip . You will have to read emulated eeprom and flash with boot mode programmer , upload data here someone of us will help you with immo off or correct your data to the original ( if you know your pin , CS , MAC and power class).
    Sent from my SM-G925F using Tapatalk
  3. The Following User Says Thank You to pepi For This Useful Post:
    super jumbe (27th April, 2019)
    Meat-Head's Avatar
    ON TOPIC:-
    is it possible to open both ecu, look for thick diode on board and voltmeter it
    see if can be repaired.
    can you put voltage meter on the bdsm port?
    OFF TOPIC:-
    i stole a faulty control module, it went dead short and blew a vehicle fuse.
    dead short went, it was internal to the board, so linked a wire from input pin to the
    regulators and bingo, decent skank.
  5. The Following User Says Thank You to Meat-Head For This Useful Post:
  6. #4
    Livingstone
    Quote Originally Posted by pepi View Post
    Thanks for quick reply have you got picture or number of emulated eeprom?
    Jun 2014
    Quote Originally Posted by super jumbe View Post
    hi, its immo5 you need avdi to adapt it by obd2, and some times you need to read eeprom flash in boot mode to load them in avdi to done the adaptation, go to youtube see our dk friend haroution he show how done by avdi. https://youtu.be/OX2amJBVWgU
  8. The Following User Says Thank You to pouleddy For This Useful Post:
  9. #6
    Livingstone
    Ok I will send ecu photo soon.
  10. #7
    Livingstone
    You can see the ECU is burnt not repareble, any one got immo off dump to write on new ECU please.
  11. #8
    EU
    Off topic:
    Wow, it looks it was powered on the wrong way with a Tesla battery.
    Sent from my iPhone using Tapatalk Pro
  12. The Following 3 Users Say Thank You to ollync For This Useful Post:
    Meat-Head (27th April, 2019), scotlock (28th April, 2019), super jumbe (27th April, 2019)
  13. #9
    Apr 2016
    uk
    I did one of these.
    Read on boot mode with ktag clone.
    Car started fine but on dash was showing SAFE...
    I uploaded the file here on dk and someone immo off it for me.don't know if worked as I found a software named "edc17off",if I remember well, and I used it.
    Software found here and eBay..
  14. The Following User Says Thank You to comizelu For This Useful Post:
  15. #10
    Livingstone
    I did one of these.
    Thanks mate I will look into folder EDC17 immo off section.
