Results 1 to 15 of 15
    May 2016
    Default Citroen DS3 626181500 crash
    hello,
    i need clear data
    Citroen DS3 2017
    Autoliv 626181500
    eeprom 95320
    CarCity's Avatar
    Nov 2016
    Inside my clothes
    Quote Originally Posted by DPRelectro View Post
    hello,
    i need clear data
    Citroen DS3 2017
    Autoliv 626181500
    eeprom 95320
    Here you go .........
    I surprise those who do not want to use the Thanks and Reputation buttons but ask for the password of the files.
  3. The Following User Says Thank You to CarCity For This Useful Post:
    DPRelectro (29th April, 2019)
    May 2016
    password please.
    May 2016
    error code U1605: Software fault: 5 programs absend or corrupted with diagnosis
    centrohifi's Avatar
    Apr 2011
    From Italy .......
    try file ....
    ..Ecu Repair ... Steering Wheel Repair ... Dash Repair ... AirBag Repair .... that Bad LiFe ...
    May 2016
    I always have the same error code
    centrohifi's Avatar
    Apr 2011
    From Italy .......
    ...mmmm test file and report ... file test 100% ok
    May 2016
    hoi centrohifi,
    I have 3 malfunctions with this file
    B160B: Fault in the load reduction command sent the 230 V unit
    Rigt-hand curtain airbag fault. Coherence fault.local
  10. #9
    centrohifi's Avatar
    Apr 2011
    From Italy .......
    these errors are also present with the original file ?
  11. #10
    Sep 2011
    try this file....
  12. #11
    May 2016
    no result 3 fault codes
  13. #12
    reproteq's Avatar
    en algún lugar de España
    hi
    try and post results.
    pm
  14. #13
    Le-Mans's Avatar
    Jun 2017
    try this clear tested solution
  15. #14
    May 2016
    reproteq end LeMansSeries
    error code remains
  16. #15
    Le-Mans's Avatar
    Jun 2017
    replace airbag ecu
