Results 1 to 8 of 8
    Member swainy's Avatar
    May 2009
    Default airbag light on vectra
    hello all does any1 know how to get airbag light off vectra mk1 pls
    DK Veteran cristec's Avatar
    Essex, UK
    Hi you could take the bulb out, or read fault codes with Op-Com or something similar, to determine why the light is on.
    HTH
    Friend of mine says he had problem with the cables under the drivers seat on an Audi..fiddled with and its ok now.
    racin-snake's Avatar
    Jun 2009
    get the codes read then you can work from there
    speculation is dangerous to your wallet
    Today is the Tomorrow you worried about yesterday ......Was it worth it ?
    Jose19's Avatar
    From the HELL
    Quote Originally Posted by swainy View Post
    You must read default codes, without that we can help you....
    Or you want take of the light
    Jose
    May 2009
    Quote Originally Posted by Jose19 View Post
    Jose
    i just want the light to be turned off not getting any codes
    The only way to get the light permanently off is to repair the problem. To repair the problem you need to read the codes, that is cheaper than trying to find the problem without any info.
    Or take the light out. However, if the light is (should) be on the entire system does not work. Maybe your choice, but what about your passengers - girlfriend, wife or children?
    Jose19's Avatar
    From the HELL
    THAT IS SO STUPID!!!!!
    NO COMMENTS!!!!
