Results 1 to 2 of 2
    Default Dpf-Egr hyundai sonata
    I would need to cancel the fap and the egr of a hyunday sonata 2.0 crdi, I tried doing with Ads Dpf Remover but it does not work.
    Thanks in advance.
    mariusica_boy's Avatar
    Quote Originally Posted by jcarballo2 View Post
    Thanks in advance.
    for correct solution dpf off +egr off u need to read bdm
    TUNING - DPF Off - EGR Off - ADBLUE/SCR Off - FLAP Off - TVA Off - DTC Off - LAMBDA Off
    If I helped you please use button Thanks.
  3. The Following User Says Thank You to mariusica_boy For This Useful Post:
    pike (30th April, 2019)
