Results 1 to 9 of 9
    sdnatlst's Avatar
    Aug 2011
    England
    Default best booster for low battery cars when key programming (UK)
    hi all, doing more cars lately with low or no power, currently have a NOCO GB40 boost pack, small compact thing. Which is letting me down a fair bit.
    i was wondering if this would be better, or what do you use please? that i can get in UK fairly quickly.
    https://www.ebay.co.uk/itm/Heavy-Dut...4AAOSwC-JbMz7V
    Done a couple of BMW's today and both had poor health batteries
    Tools owned -
    Mar 2018
    UK
  3. The Following User Says Thank You to Manta1600 For This Useful Post:
    sdnatlst (30th April, 2019)
    jodge's Avatar
    Mar 2017
    https://www.bannerbatterien.com/en-g...ner-P3-Evo-MAX
    not chep but one of the best, on the page bottom you can see the spec
  5. The Following User Says Thank You to jodge For This Useful Post:
  6. #4
    sdnatlst's Avatar
    Aug 2011
    England
    Cheers!! looking for something in UK for next day delivery and around £200 mark
    Tools owned -
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Booster is not for flash. For flash you need 15v 50amp power. Cheapers handmade cost around 250-300,good supply cost from 500-700eur.
    Those boosters is joke,its just to start car,but not flash
  8. The Following User Says Thank You to drugowaz For This Useful Post:
    p1et (1st May, 2019)
  9. #6
    sdnatlst's Avatar
    Aug 2011
    England
    Im not needing to FLASH i just need to make sure current is stable 12V+ while key programming
    for example today i had BMW 2006 and owner was not home, car was in street, no access to outlets....the battery was poor only 11V, struggle to even start car..... i just needed to add a new key here but had some trouble because of voltage problem.
    another example i went to peugeot 407 AKL in tesco car park, battery was flat dead,,, my little booster did not give enough to make over 12V on this and it made PIN read very difficult.
    hope that helps why i need some mobile power booster/stabiliser
    Tools owned -
  10. #7
    Mar 2018
    UK
    With this one from Halfords you can work all day without problem
    I'm using it last 4 years
  11. #8
    Oct 2018
    Northern Ireland
    I use jump pack on the likes of Vauxhall or anything with a dodgy battery or security timer. Leads were always too short on these jump packs so a bollocks. I got 10mm welding lead jointers and a set of jump leads and cut one clamp end off the jump leads and put male welding jointer on and female on jump pack leads after cutting clamps of it. Really good job now no jump pack sitting in engine bay and handy packed up
  12. #9
    Apr 2016
    uk
    I use this
    https://rover.ebay.com/rover/0/0/0?m...2F163499104319
    I use it on my 4000w inverter.
    Works well for me.
