Vivaro 2.5 Dash + milage & Oil light reset problem - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 29 of 29
  1. #16
    Jan 2018
    Quote Originally Posted by urametz View Post
    Where service data changes have long been known this is the area 0000134 - 0000153. You can put 0 or 20,000 to the service. But here I understand the problem in another. The man is a little off topic. He already had a problem with this dash: https://www.digital-kaos.co.uk/forum...66-with-board- computer .
    Over the past year, if desired, it was possible to parse the entire dump dash byte-bye. And here we are spreading on the tree is useless.
    As you can see, this problem has been appearing for a long time.
    Unfortunately, no one could help me with the first instrument cluster.
    So I bought a used one and now the problem appeared but of a different nature.
    Bought counter had 235k miles so I changed to 168.870 that mileage was last known.
    After a while, the service light was come on and I added milage 5k and it was possible to reset the service .
    Now the control lights again but nothing helps. Adding miles, etc ...
    ""Where service data changes have long been known this is the area 0000134 - 0000153""
    Can you provide more information. Please
  2. #17
    Jan 2018
    Quote Originally Posted by Bllinda View Post
    Why should I help you? You couldn't help anyone over the years
    View the eeprom where data is changing
    Dear Bllinda
    When my experience, although it approaches yours and I can then help someone , I will certainly do it.
  3. #18
    Jan 2018
    Unfortunately, RENOLINK can not change the mileage. in vivaro
    When selecting extras and reading, it shows a CAN error
    Maybe it's my poor knowledge of French but I'm stuck.
    All attempts end with the same.
    The Renolink readout shows correct values
    "lecture des km fournis par TDB_service_UCH2001 (km)" 272724km
    "lecture des km memorises dans and UCH_UCH2001 (km)" 272724km
    So maybe someone has any suggestions ??
  4. #19
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    What are you trying to do km in
  5. The Following User Says Thank You to teerak2uk For This Useful Post:
    robarco (5th May, 2019)
  6. #20
    Jan 2018
    Quote Originally Posted by teerak2uk View Post
    All indications in RENOLINK are in KM / EU (1km= 0.625 miles)
    But I found only these two indications from the last post.
    "lecture des km fournis par TDB_service_UCH2001 (km)" 272724km = 170.452 miles
    "lecture des km memorises dans and UCH_UCH2001 (km)" 272724km = 170.452 miles
    I am looking for help in:
    Resetting the inspection.
    If it points to the problem in the difference between the speed and the ECU
    So I'm looking for where it's saved
    last inspection with a mileage ????
    where should I know what should be.
    If I can't changed in ECU or UCH ??
    I put in a speedo with the same part number as the previous one -milage of 230+k and the inspection lights up. It can not be deleted with the combination of pedals. So, I have been trying to clear the inspection and the error of poor oil quality oil for a week. Unfortunately, without success.
    Van he lost his power, the inspection, the service and the glow plug light are on
    there are several sets hardware available and none work as it should .
    Clip, Delphi, OpCom, Renolink, each shows different values.
    a real nightmare
    The problem is that, I am looking for more and I read the less I know.
    There are so many posts and everything that it's really hard to understand anything.
    Nobody will write a simple answer , it seems that no one has any answer.
  7. #21
    Nov 2016
    Hi, try
    1. Turn on the ignition (key in position II)
    2. When the km limit for service inspection has appeared, press the gas pedal all the way.
    3. Press the gas pedal all the time and press the brake pedal 3 times.
    4. Let go of gas, turn off the ignition and turn it on again
    If this does not help, check the brake pedal sensor for a signal to ECU, eg in real values, This sensor is often a problem because the stop is on but there is no 2 signal to ecu.
    If you have errors in ecu, delete them before the procedure.
  8. #22
    Jan 2018
    Quote Originally Posted by Stopro92 View Post
    Hi, try
    fault code P253F is stored in the Engine Control Module
    Unfortunately, after deleting it returns after 2 seconds.
    So it is not possible to delete this error before deleting the service inspection.
    Car in emergency mode.
    Light glow plugs, service, and key symbol on the LCD. ON
    pedal combination procedure - it did not work.
    Resetting the ECU by disconnecting the battery does not help
  9. #23
    Nov 2016
    Have you checked the brake sensor as I said? Try to still press the brake pedal more than 3 times
  10. #24
    Feb 2017
    Baltic
    use can clip to check engine ecu km. dash km has to be higher than engine ecu km for that service reset to work...
  11. #25
    Jan 2018
    Quote Originally Posted by mikkhh View Post
    Unfortunately Clip corrupted, the probe will not update.
    I have
    OPCOM, Delphi, Renolink
    Delphi results:
    Engine oil quality 271910km / 169.943 miles
    DPF distance travel 280503km / 175.314 miles ----this indicates that the milage should be 175 943
    Odometer 272724km / 170.452 miles
    dervice interval data-dist. travelled since last insp.... 4,294,967km // 2.684.354 miles ???????
    How to check engine ecu milage by Opcom or renolink ????
  12. #26
    Nov 2016
    Maybe it is better to read the ecu eeprom and the meter and have the same waveforms? The difference can be 10km
  13. The Following User Says Thank You to Stopro92 For This Useful Post:
    robarco (6th May, 2019)
  14. #27
    Jan 2018
    EEP read by renolink but Only how to decode this from the bin file ??
    Today
    Unfortunately, the mileage reading from Renolink which concerned the DPF 175.314miles
    is not appropriate. I can't still delete the inspection or error .
    I do not know how else I can check the actual millage in ECU without Clip ??
  15. #28
    Nov 2016
    I do not know in what Renolink file records because I do not have this device
  16. #29
    Jan 2018
    New clip arive.
    I would like to know where to check what is the mileage in ecu or in UCH.
    Can someone give some tips.
    I have a whole eep read by Galletto downloaded about 1.5 years ago.
    But here, too, I only know the mileage in approx.
    Will it not be easier to write this file into the ECU and to re-code the injections.
    Will ecu reset help in this case ??
    Renolink, I have only a blue sx cable in French, so now I am looking for an English version.
    Which version works with the blue SX cable.
