i had a same trouble some years ago the only way to make it was to find to put a swicht on can line through ABS CAbleand use the switch whe you wantgo over 95 km obviusely the lights of abs stay on when switchted i hope to help you regards
Speed in eeprom.
FILE SERVICE
Hi Voltecar. Can you set speed limiter on (to 90km) in this car when i read eeprom and flash via bdm points? Or explain how to set speed limiter on via diag with Clip ? If its possible.
I can, but better use clip and set in ecu. Yours choice
FILE SERVICE
I do not have car by me. Tomorow they will bring me ecu only, because tomorow they travel (not with Renault Master) through my city. If i must to go there (75km in one direction) i will go, but i preffer not to go. Car is now without speed limiter.
Here is ori eeprom and flash without speed limiter. I need to set speed limiter to 90km. ECU is 0 281 012 200, Renault Master soft 1037372310.
Thank you
Peter2019
hi change speed limit to max 250km/h
test and report
thnx ....................... pass pm
credoline (15th January, 2020)
Send pass please
bidu20 (21st April, 2021)
